elmic11111
Sep 27, 2022Tutor
Unable to Unblock a device
I have a RBR850 running firmware V4.6.9.11. I recently blocked my TV to stop my son from watching stuff. I went to unblock it later to find that I can't. In the Orbi mobile app it doesn't provided an...
Sep 30, 2022Guru - Experienced User
Any Progress on this?
Were you using Smart Parental Controls?
Might have to reset the RBR and setup from scratch.
- elmic11111Sep 30, 2022TutorYes on parent control. I saw posts with other having similar issue and end up breaking down to factory reset it.
- FURRYe38Oct 02, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
