Surge74
Aug 11, 2020Aspirant
Update to 2.5.3.108 no longer shows satellite connection status accurately
The recent firmware update to 2.5.3.108 has caused my 2 Satellites to no longer show as connected in the NETGEAR Insight App. Sometimes they show as connected, but most of the time they show as not co...
PSwifi
Aug 13, 2020Tutor
SRR60 also not connecting to satellites consistently. Advisor says to role back to firmware version previous to 2.5.3.108. Whatever is wrong with this update Netgear need to fix it, and at least aqnowledge there is a problem. I have found no statement by Netgear that there is a problem with this update. Once I finally got to a Netgear advisor they were very helpful, including calling me back.
Surge74
Aug 13, 2020Aspirant
Netgear did acknowlege to me that they are aware of this issue and are working on a fix.
- rcmusukAug 30, 2020Aspirant
update to firmware 2.5.3.108 still won't allow satellites to connect to router......very frustrating that this continues....spent the last two weeks trying every reboot imaginable
- Retired_MemberAug 30, 2020
Better than me. The update renderend my Orbi useless. It would just flash while. I have to factory reset 3 times for it to stop boot looping.
just got everything back up and running. It's still running 2.5.3.108 after all that and it seems ok. It's connected to my Satellite fine.
