orbcad
Feb 11, 2021Guide
Updated Orbi RBR50 and RBS50 to 2.7.2.104 - Satellite Link Rate issue now
Updated to latest firmware as per the update notification. All went well. However one issue that has started is all the devices that connect to the RBS50 satellite show a link rate of N/A. In add...
alokeprasad
Feb 11, 2021Mentor
CrimpOn wrote:
orbcad wrote:Updated to latest firmware as per the update notification. All went well. However one issue that has started is all the devices that connect to the RBS50 satellite show a link rate of N/A.
My experience as well. WiFi devices connected to the RBS50 show link rate of "N/A" while devices connected to the RBR50 and to the RBS40V show actual link rates.
Where do you see the link rates of attached devices?
All I see in "Attached Devices" on the web interface is "wired" or "2.4G" or "5G" doe each device.
For example:
Feb 11, 2021Guru - Experienced User
They are referrging to the Orbi App.
I see same thing in the Orbi App, link rate is NA.
- alokeprasadFeb 12, 2021Mentor
FURRYe38 wrote:They are referrging to the Orbi App.
I don't see link rates in the iOS app. I could post screenshots ..
Maybe it is an Android app only feature. iOS blocks many low-level info from 3rd party apps.
- FURRYe38Feb 12, 2021Guru - Experienced User
Select on a device in the app and Link rate is towards th bottom of it's information screen on the app.
I see it now. Strange that some info is on the app but not the web interface ...
A few observations (all for WiFi connected devices):
- Devices connected to the RBS don't show the link speed.
- One device connected to the RBR shows "inactive" but is clearly connected and active.
PS: When I checked 10 mins later, it was shown as active and had a link speed.
The attached devices feature, at least on the app, is touvh and miss. It also depends on when the app polls the network for traffic from the devices.
