staceyw5
Jun 15, 2019Aspirant
updating firmware
My orbi is running a very old firware (1.4 something) and I want to update it, (I have to do it manually, will not work through app). I downloaded the files on my macbook, and when I go to open it I ...
Jun 15, 2019Guru - Experienced User
You don't actually open the .img file. Download the file from the netgear support site, extract it, and then upload it through the web browser. you'll go to advanced--administration--router update. Use the manual installation method
Keep in mind, you must update to version 2.2.1.212 and then you can update to the most recent version. Here's the support site with the firmwares and the manual that walks you through installation.
https://www.netgear.com/support/product/RBR50.aspx
- staceyw5Jun 16, 2019Aspirant
This is exactly what I did..... but when i go to upload it is says "please select correct configuration file". What I am trying to upload is
RBS50-V2.2.1.212.img, and that is when i get the error
- plemansJun 17, 2019Guru - Experienced User
One thing to check. the RBS file is for the satellite and the RBR file is for the main router. Make sure you're using the correct firmware for each. I downloaded the .img file and it worked fine so long as I was on the correct device.
- plemansJun 20, 2019Guru - Experienced User
Did you get it working?
- staceyw5Jun 20, 2019AspirantNot yet.... support is giving me all the things I have tried. They did give me a link to 1.12 to try. I’m not home until Saturday but will try that then. They also told me the shelf life of my product was old. Produced 2017 and purchased 2 years later. Which is very frustrating Walmart would be selling an old product.
