robtester
Sep 04, 2023Aspirant
V4.6.14.3_2.3.12 firmware unable to pause device from app
Hello, We are on latest firmware of V4.6.14.3_2.3.12 for our Orbi mesh product. It seems that the pause/un-pause functionality from Orbi app no longer works. The app shows that it is paused; ...
Apr 09, 2024Guru - Experienced User
What model RBS do you have? 750s?
Your system is behind on FW:
robtester
Apr 13, 2024Aspirant
Yup, the satellite is also RBS 750.
You are right that I am behind firmware versions. I've updated both router and satellite to V7.2.6.31_5.0.24 and the pause/play functionality still does not work.
I guess this goes to a separate bug report. The reason why my firmware was behind was because the "check updates" firmware functionality was telling me I am on the latest version. Gosh.. just one bug after another.
Rob
- FURRYe38Apr 15, 2024Guru - Experienced User
Some systems may not be included in the newer FW, NG may not auto update or push newer versions of FW, some minor versions don't get pushed, or users have the auto update feature disabled as NG put this user option in back in v4 version of FW.
Good Luck.
