amweiss
Jul 15, 2022Tutor
Web Connection Ok, but App says Can't Connect and Offline
I have an RBR 850, bought one year ago, and was working fine until last week. What is strange is that the orbi mobile app says it can't connect and it's offline but the web interfaces say all is goo...
amweiss
Jul 15, 2022Tutor
one more piece of info...I thought originally the problem was with my iPhone, but the problem shows up on all the other mobile devices connected to this router
Jul 16, 2022Guru - Experienced User
and
- amweissJul 17, 2022Tutor
I turned off Limit IP Address Tracking and Priviate W-Fi Address. It still goes periodlcally in into offline mode. Unfortunately, but this is the case.
- FURRYe38Jul 18, 2022Guru - Experienced User
Is Local Network enabled for the Orbi app on the mobile device?
- amweissJul 18, 2022Tutor
answering again since it doesn't appear my recent response was posted.
Yes, local network is turned on for the Orbi app
again, my modem is the ARRIS SURFboard SB8200 DOCSIS 3.1 Gigabit Cable Modem
