zigor911
Feb 10, 2023Aspirant
Wifi device names in ORBI App as N/A
After latest FW update of my ORBI setup and I am using latest Orbi app on iPhone too: the names of the devices attached to Wifi (either 2.4g or 5g network) now displayed as N/A, though correctly show...
- Feb 13, 2023
Update: what worked for me was to delete the Orbi app, including its data, and re-install from the App Store. It will require to login again to the Netgear account, and then will find Orbi on the local network and will prompt to login as Admin. Now device names are correctly displayed.
zigor911
Another interesting thing happened after latest FW update of my ORBI setup and I am using latest Orbi app on iPhone too: the names of the devices attached to Wifi (either 2.4 G or 5g network) now displayed as N/A, though correctly shown on the Orbi admin web page. What is this???
KellyOrbi
Feb 12, 2023Apprentice
I've got a similar issue. Many devices on my iphone app are showing as "N/A". Some are showing the actual device name like they should. Connecting to my CBR750 on the computer correctly shows all the device names. I've tried rebooting the router, uninstalling and reinstalling the app on my Iphone but I still have the same problem.
- FURRYe38Feb 12, 2023Guru - Experienced User
Both, please submit a bug report thru the Orbi app:
https://community.netgear.com/t5/Orbi-App/How-to-report-a-bug-on-the-Orbi-App/td-p/2140980/jump-to/first-unread-messageThank you.
- KellyOrbiFeb 12, 2023ApprenticeOk. I reported the problem.
- zigor911Feb 12, 2023AspirantOk, submitted the issue. Let’s see what happens next…
- zigor911Feb 13, 2023Aspirant
- FURRYe38Feb 13, 2023Guru - Experienced User
Great to hear. Thanks for letting us know how you solve it.
Hope it helps others seeing this issue.
Enjoy.
- KellyOrbiFeb 13, 2023Apprentice
I did try deleting the Orbi app, rebooted the phone, reinstalled from the appstore and signed in. I still have the same problem. You mentioned that you "deleted the data" - how exactly did you do that?
on Iphone, when i delete the app, it warns me that app data will be deleted as well, I just confirmed to proceed deleting app data.
OK. I did that. I just wanted to make sure i wasn't missing a step.
- Grumpy_BearJan 11, 2024Initiate
Hi Kelly, did you managed to resolve your issue eventually?
- KellyOrbiJan 11, 2024Apprentice
Yes, it has been resolved for a long time. As I recall, deleting the app and reinstalling did not work. I think i ended up doing a factory reset.
