zigor911
Feb 10, 2023Aspirant
Wifi device names in ORBI App as N/A
After latest FW update of my ORBI setup and I am using latest Orbi app on iPhone too: the names of the devices attached to Wifi (either 2.4g or 5g network) now displayed as N/A, though correctly show...
- Feb 13, 2023
Update: what worked for me was to delete the Orbi app, including its data, and re-install from the App Store. It will require to login again to the Netgear account, and then will find Orbi on the local network and will prompt to login as Admin. Now device names are correctly displayed.
Feb 12, 2023Guru - Experienced User
Both, please submit a bug report thru the Orbi app:
https://community.netgear.com/t5/Orbi-App/How-to-report-a-bug-on-the-Orbi-App/td-p/2140980/jump-to/first-unread-message
Thank you.
KellyOrbi
Feb 12, 2023Apprentice
Ok. I reported the problem.
