awill2run
Jun 24, 2021Aspirant
"Wifi Not Detected" on Orbi App, phone connected to wifi through Orbi router
orbi app giving the message "WiFi Not Detected" even though the phone has internet access through the orbi router. I have uninstalled and reinstalled the app, rebooted phone and orbi system, still no...
Jun 25, 2021Guru - Experienced User
what modem/gateway is it connected to?
awill2run
Jun 25, 2021Aspirant
Thank you for asking but I’m not sure I know the answer to your question… we have the modem from our ISP: Arris TM1602A
- plemansJun 25, 2021Guru - Experienced Useryou have the arris tm1602a modem.
what orbi setup is it? (model)
what firmware is on it?- awill2runJun 25, 2021Aspirant
Orbi model RBR750
Firmware: I am having the most difficult time accessing firmware through orbilogin.com. There are 3+ minute lag times in between each command only to end each query with "The connection was reset" or it takes me back to the page to enter my router's serial number ... it's beyond frustrating
- plemansJun 26, 2021Guru - Experienced User
you might get better luck in the orbi AX forum where they're more familar with orbi AX specific issues.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
