Stevey
Dec 23, 2019Follower
Wired router
Hi. I was looking for a wired router... does Netgear not make one?
I wanted to have a router connected to a switch that then feeds to wifi access points throughout my house, but can't seem to find a good router without wifi?
unless they have routers built into switches? I'm looking for something under $300
Thanks
edit; sorry this is in the wrong board but I don't know how to change it.
1 Reply
You can buy a regular router and just disable the wifi on it if you want to stay in the consumer setup of routers.
Or you can look at something like Ubiquiti edgerouter line.
