bipoole
May 02, 2021Aspirant
‘Mystery’ Satellite Appears in ORBI APP !
I have ORBI APP on my IPad which, until now, has worked fine. My network consists of one RBR750 browser and two ORBI satellites. However, today the ORBI APP is showing a 3rd satellite which is iden...
May 02, 2021Guru - Experienced User
Factory reset the RBR and RBS and setup from scratch. Should clear the phantom RBS.
- tak1313May 02, 2021Luminary
It happened to me a while back too - except my new phantom satellite was a Xerox (of all brands).
It's just a demonstration of the superb skills of Netgear's coders. If I recall, all I did was delete it through the browser ui and it never showed up again.
- bipooleMay 03, 2021Aspirant
Thanks for info. Now, if I can figure out how to do factory reset and all that entails I'll be OK
- FURRYe38May 03, 2021Guru - Experienced User
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ - tak1313May 03, 2021Luminary
bipoole wrote:Thanks for info. Now, if I can figure out how to do factory reset and all that entails I'll be OK
I recall that by just deleting the mysterious object from the browser ui page (attached devices), no factory reset was necessary - it just disappeared from the app at the same time. At least I don't recall having to do a reset. But then on the other hand, I don't recall a lot of things these days...
