HomeUserguy
Dec 30, 2021Aspirant
1 -2 times per day router goes offline
I have an rbr850 on the latest firmware however 1-2 times per day the system completely goes offline (like a reboot) everything in the house wireless or wired loosed connectivity. Its random but see...
Mar 07, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- MikeS2021Mar 07, 2022AspirantFirmware is 4.6.7.13 on all 3.
Service provider is Spectrum, modem model E31T2V1.
Home is just over 4k sqft. Satellites are spread way out.
It’s all been working fine for over a year now.- FURRYe38Mar 07, 2022Guru - Experienced User
Is there a front LED when this happends on the RBR?
- MikeS2021Mar 07, 2022AspirantSatellites are over 50ft from each other.
I believe the front of the router is pulsating blue/white until it reconnects.
Are there not log files to indicate what is going on with the device?
The last firmware was applied many months ago, but the issue is much more recent.
