Rogelio1
May 15, 2020Apprentice
160Mhz for Mesh?
I know the Orbi 6 AX6000 doesn’t support 160mhz currently. Could it ever (is this a hardware limitation or firmware)? I ask because I have gigabit internet and see some routers do 160Mhz and get to...
Rogelio1
Okay — so I see another thread where it’s mentioned the 160mhz band is part of the 802.11ax standard. This may be true, but then why do some AX standalone Netgear routers clearly say 160MHz support whereas that’s nowhere to be found for the AX6000 Orbi?
I’m assuming since it’s listed as AX6000 there will never be an intention of having a software option to use the 160MHz band. Has this been confirmed?
- CallPaulMay 15, 2020Apprentice
Because the AX Orbis don't support 160mhz channels on the user available bands. The backhaul channel is 160mhz and it runs at 2400 mbps. There's not many AX clients that currently run on 160mhz channels (some laptops), nothing on iOS.
- Rogelio1May 15, 2020Apprentice
Doesn't support it on user available bands (as in, not implemented in firmware... or not supported by hardware)? I would think since the two 5GHz radios are identical in hardware, and since the one dedicated to backhaul is operating at 160MHz channel width, that the other radio dedicated to the actual client-end broadcast would similarly be capable of broadcasting at 160Mhz width.
Depends on the 5ghz radios that are used. It may be a firmware update or they can't do 160mhz because of hardware. I'd ask Netgear.
