Rogelio1
May 15, 2020Apprentice
160Mhz for Mesh?
I know the Orbi 6 AX6000 doesn’t support 160mhz currently. Could it ever (is this a hardware limitation or firmware)? I ask because I have gigabit internet and see some routers do 160Mhz and get to...
kildare
May 15, 2020Luminary
Rogelio1 wrote:
Are there any mesh devices (not just Netgear) that do 160Mhz, or is this only found in stand-alone single point routers?
I know the Asus ZenWifi AX that has two 5 GHz bands, the second has 160 MHz channel bandwith and by default is used for the wireless backhaul up to 4800 Mbps.
But thanks to the configuration settings available, each of the 3 bands (2.4 GHz + 2 x 5 GHz) can be used as the wireless backhaul, so the 2nd 5 GHz band can be devoted to wireless clients.
Moreover, if using a wired backhaul, all the 3 bands can be used by wireless clients.
