alphagamma21
May 19, 2022Follower
"192.168.1.1 refused to connect."
Factory Reset does not work. Issue persists. "192.168.1.1 refused to connect."
I also can no longer print. The router does not seem to allow my printer to connect. It worked fine yesterday....
May 19, 2022Guru - Experienced User
Did you press the reset button for 15-20 seconds then release and connect a wired PC to the back of the RBR and use a web browser to connect at 192.168.1.1?
Try different browser?
