alphagamma21
May 19, 2022Follower
"192.168.1.1 refused to connect."
Factory Reset does not work. Issue persists. "192.168.1.1 refused to connect."
I also can no longer print. The router does not seem to allow my printer to connect. It worked fine yesterday....
May 19, 2022Guru - Experienced User
What router do you have?
And what modem/gateway is it connected to?
You didn't put that and some of the combo devices use a default 192.168.0.1 address.
Or if your gateway is a combo device, the router might default to the 10.0.0.1
thats why details are key
what are the led's on it doing? (all of them, color/blinking/etc)
