Orbidude
Dec 29, 2021Guide
2.4 Ghz Digital Frame doesn't work with RBR850 and 2 satellites...
Hi, I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took...
Dec 29, 2021Guru - Experienced User
Are they able to connect to the 2.4ghz?
You can see the devices connected to the network?
What modem/gateway is the router connected to?
