Orbidude
Dec 29, 2021Guide
2.4 Ghz Digital Frame doesn't work with RBR850 and 2 satellites...
Hi, I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took...
Mikey94025
Dec 29, 2021Hero
Orbidude wrote:Hi, I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried.
I see in your other thread that the problem was your frame was connected to the wrong network.
- OrbidudeDec 29, 2021Guide
Hi Mikey,
It's not that the frames were connected to the wrong network. I think the frame was getting confused as to the 2nd router in the same room. As soon as I took the frame into another room, everything worked as it should. If in a couple days I'm having issues, I'll try your suggestion of disabling the 2.4 Ghz band.
Thanks, I appreciate it.
