WilBloodworth
Jun 28, 2020Tutor
2.4 GHz on Orbi AX4200 (RBK752)?
Is there no way to connect specifically to the 2.4 GHz channel instead of the 5 GHz channel? I have tons of devices that I cannot configure because my computers and phones automatically connect to t...
Jun 28, 2020Guru - Experienced User
Not at this time.
You can turn down the power out put of the 5Ghz radio on the RBR and take your setup device at to a distance where it will only connect to the 2.4Ghz radio. Turn OFF the wifi radio for 5 seconds then back on. Then get your devices connected. After they connect, then turn up the power on the 5ghz radio.
