acchen
Jul 06, 2022Follower
2.4ghz wifi fo my satellites disabled again⋯
This method only worked like a day for me, and 2.4ghz wifi fo my satellites disabled again⋯ Is there other way to solve this problem?
Jul 08, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try setting manual channel 1, 6 or 11 on 2.4Ghz on the RBR.
Has a factory reset and setup from scratch of the RBR and RBS been performed since last update?
