Jwarder969
Aug 07, 2023Follower
2 ghz cctv cameras cannot connect to Orbi RBR760
I have an Orbi RBR760 3-pack system. 1 router and two satellites. I have a large home hence the reason for this purchase. Upon setting it up, we found out that our Uniden cameras will not connec...
michaelkenward
Aug 08, 2023Guru - Experienced User
Jwarder969 wrote:
I have a large home hence the reason for this purchase. Upon setting it up, we found out that our Uniden cameras will not connect to the Orbi as they will only run on 2 ghz. As I cannot separate the channels, how on earth do I enable the cameras to be seen by my Orbi?
That is a tell tale sign of badly written installation software for your IoT cameras. People turn up here regularly with similar takes of woe. There are various strategies that you can take.
Your first move should be to ask Uniden how you are supposed to connect to a Mesh router that uses smart connect and a single SSID.
You could also look at whatever mobile you are using to set up the cameras and see if you can tell it to connect to 2.4 GHz wifi.
Then there is this:
