SmokyBBQ
Jun 13, 2024Aspirant
2 RBR760 in AP mode connected via Ethernet to ISP router
Hi All I started with one RBR760 and 2 RBS760 satellites in AP mode connected to my ISP router (Telstra smart modem 2) which was working well. I just ran Ethernet from the ISP router to a seperate ...
Jun 13, 2024Guru - Experienced User
Try taking out the 2nd RBR and run the 2nd line/building off the main orbi router. You can hardwire in the satellites to the orbi
SmokyBBQ
Is there any way to still use the RBR? I'd prefer to get the extra coverage of two units.
- SmokyBBQJun 14, 2024Aspirant
I've got both Orbi 760 routers in AP mode and both are ethernet connected to the ISP router. I've left them both with default SSID (OrbiXX and OrbiYY). My hope was to have 2 separate mesh networks (one in the house, one in the external office). Each works fine on their own but when I power up both at the same time the satellites drop connection (purple lights). The routers themselves keep working.
- plemansJun 14, 2024Guru - Experienced User
When you're setting up the sateliltes for each system, shut off the other system. maybe they're syncing with the wrong orbi router.
Also, make sure the bands are separated so they're not on the same channel and you have a different ssid.
