PeterJGVDP
Oct 18, 2021Guide
2 RBR850 in one mesh
Hello, I have recently purchased a wifi6 ORBI RBK852 mesh set, and I’m now able to purchase another RBK852 set from a friend and i was wondering if it is possible to combine these two sets, so th...
- Oct 19, 2021
No. The 2nd RBR in AP mode will not be included or integrate in the 1st RBRs mesh system. Will be a separate wifi signal though using same SSID name and PW and different channels.
Also recommend turning down the power output of the 2nd RBR wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Helps limit the noise and some interferences between the 2nd RBR and 1st orbi system signals. Use far appart channels between each RBR as well.
ekhalil
Oct 19, 2021Master
You can use the second RBR by setting it in AP Mode.
The second router can have the same SSID as the main router but make sure to use different radio channels for the two bands in the two networks and that both have the same pass phrase.
Since in such setup you only have one main router whose NAT function will assign a port number and remember the clients details for a returning packet. Packets will therefore not be lost if the client device changes its WiFi connection to the other router as NAT information is held in the tables of only one main router.
- PeterJGVDPOct 19, 2021GuideSo, in this setup it's possible that both RBR850's and both RBS850's will function in one mesh, all in AP mode (with the described correct settings)?
- FURRYe38Oct 19, 2021Guru - Experienced User
