BiggusDiggus
Dec 10, 2023Aspirant
2 RBR860s, 1 Router, 1 AP
I am trying to use a second RBR860 I got for practically free instead of a satellite. My setup is currently the ATT Fiber modem in passthrough wired to the Main Orbi downstairs (WAN). Then, in one of...
- Dec 13, 2023
Try this. Press the power button on the xbox consoles until they shut off, then release the power button.
Power cycle the ISP modem or ONT and the RBR OFF for 1 minute then back ON with the ISP modem or ONT, then RBR. Once that system is up and running, power ON one xbox console. Check NAT status. Then power on the 2nd xbox console and check NAT status.
BiggusDiggus
Dec 12, 2023Aspirant
The ATT Gateway is in passthrough. That's why I don't understand.
Dec 13, 2023Guru - Experienced User
