AJTsolutions
Jul 28, 2020Follower
2 sets of RBK853-100NAS
Can I get 2 sets of RBK853, configure 1st set to router mode and the 2nd set will be AP mode? Will that work? Will that will give me 5 satellites together? I need more satellites due to farm house thick walls and the house about 8k sqft. I guess the issue might still be the backhaul channel going through? I might be able to hardwired at least 2 satellites. Will that help on the daisy chain? Thanks for the help.
1 Reply
Yes, however would be only 4 RBS total that would be connected to 1 RBR. The 2nd RBR can work in AP mode however would need to be on a separate SSID name and far appart channels from the 1st RBR.Yes you can ethernet connect RBS to the main RBR.
