arune00
Jan 19, 2023Follower
2022 Subaru won’t connect to my orbi WiFi mesh system.
I recently purchased a 22 Subaru WRX and it won’t connect to my Orbi. My 21 WRX connected fine. My 22 will not. Sometimes it says it can’t connect. Other times it says the password is incorrect. I’ve...
Jan 19, 2023Guru - Experienced User
You're using the RBK750 kit?
What firmware is on the router?
And on the satellites?
What modem/gateway is the router connected to ?
Are you using ipv6?
Are you using any special characters/spaces in the ssid/password? If so, remove them
