Aggie88
Feb 11, 2025Apprentice
20/40MHz Coexistance (RBK963)
I have tried responding to the thread titled "Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks" twice now. Yesterday's response disappeared in a couple of hours and today...
Feb 12, 2025Guru - Experienced User
20/40Mhz only effects 2.4Ghz devices. Would not effect RBS connections or 5Ghz.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
