Aggie88
Feb 11, 2025Apprentice
20/40MHz Coexistance (RBK963)
I have tried responding to the thread titled "Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks" twice now. Yesterday's response disappeared in a couple of hours and today...
Aggie88
Feb 12, 2025Apprentice
About 4000 sq feet over 2 floors. RBR is in the basement centrally located and the two satellites are at opposite ends of the house and each is about 30 feet apart straight line. Satellites are hardwired. Power is set to 50 percent. Wireless is set to channel 1, 40, and 69 for 2.4, 5, and 6Ghz channels respectively. Yes, all IP randomizers are turned off at home.
Thanks!
Aggie88
My neighbors aren't interfering with my system per a scanner I use. We're on different channels and the houses have good separation between them.
