rahtikan
Aug 24, 2023Follower
24ghz mbps slower than 5ghz
is there a reason my 2.4ghz speed is 268 but my 5ghz is 1GB even though my ISP is showing 1GB of speed to my router
Yes. 2.4Ghz is not as fast and 5Ghz.
Orbi AX5400 Router and AX5400 Satellite
(600+2400+2400Mbps)† - plemansGuru - Experienced User
Its significantly slower and its more sensitive to interference. What you're seeing is an expectation of 2.4ghz.
This is a good article if you want to understand wifi specs and performance more.
https://www.duckware.com/tech/wifi-in-the-us.html
