a804570
Dec 19, 2025Follower
2GB into RBR860 but only 1GB out.
I recently upgraded to 2gb internet service but while the router speedtest shows 2GB coming in, my computers are only getting 1GB service. I've replaced all my 1GB switches with 2GB switches and hav...
KevinLiT
Dec 25, 2025NETGEAR Moderator
Hello a804570 ,
Welcome to the NETGEAR Community!
I understand that you upgraded your network service from your ISP and you are noticing those expected speeds (2Gbps) at your router. However, your LAN devices seem to be capped at 1Gbps. This is because your RBR860 uses four (4) 10/100/1000Mbps Gigabit
Ethernet LAN ports. The only port that is compatible of more than 1Gbps is the WAN port.
Please navigate to the link below for additional technical specs for your RBR860:
https://www.netgear.com/support/product/rbr860 (Product Data Sheet)
Best,
Kevin
NETGEAR Team
