MP123098
Dec 27, 2022Tutor
2nd hand Orbi from Amazon - unable to connect
Hello all, I brought a second hand Orbi from Amazon and I can’t get it to connect. I take it through the set up stages and keep getting a message it cannot connect. I have followed instructions fro...
Dec 27, 2022Guru - Experienced User
Use a wired PC and web browser to setup the RBR.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
MP123098
Dec 27, 2022Tutor
Thanks furrye38!
I have added comments and more questions below to your questions.
Use a wired PC and web browser to setup the RBR. - I did try, but even with the Orbi connected to my Virgin router via a cat 7 Ethernet and the laptop to Orbi, there was no internet. Connecting to my internet provider I had connection but couldn’t connect to the 192…. Address suggested in previous forum. Which connection should it be? Orbi or my provider.
What Firmware version is currently loaded? No idea I haven’t been able to make it far enough to check this.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Virgin media - hub 4
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? Yes this done each time, but no software update requested from the Orbi. Should it be?
Yes this has been followed
Yes I have tried this. At first the light would only go red, but after a few times I had it going orange and flashing orange before it went red then green. Is that what is expected?
Thanks again
Thanks again
- FURRYe38Dec 27, 2022Guru - Experienced User
WIth the RBR disconnected from the modem and after a factory reset, are you able to access the RBRs setup web page at 192.168.1.1 at all?
FYI your ISP modem has a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #2 first...
