fraczek12345's avatar
fraczek12345
3.2.9.2 Orbi Wifi 6 router not showing Satellites in the app and also in orbilogin website
3.2.9.2 Orbi Wifi 6 router not showing Satellites in the app and also not in orbilogin website. When I check the map or attached devices there's only my router and nothing else but they work fine. I ...
  • FURRYe38's avatar
    Well having the RBS not on the same FW can be one problem.
    You might factory reset the RBS and RBR and setup from scratch. If this still happens after the reset, swap around the RBS to see if the disconnection problem follows. If it does, then possible faulty RBS maybe at play here.
    I just loaded v10 FW on my system in AP mode. Both RBS show connected. I didn't factlry reset mine though. One is wireless, One is wire connected. Shows correctly in the Orbi app. https://community.netgear.com/t5/Orbi-AX/ORBI-SAMSUNG-TV-BT/m-p/1861347/highlight/true#M1283
    Try this if your interested.
    If your phone is connected to the RBS that are wire connected to the RBR, it will appar as a wire connected device. If you connect the phone to the RBR, it should appear as wireless. This is normal
