SarahJs
May 22, 2024Aspirant
5/22 Update and one router will not reconnect
The good news is for the first time since I have had my RBK653 tri mesh system, I was actually able to update the router via the Orbi app. I received a message to update, so I did. All appeared to ...
- May 24, 2024
Not sure if or when that will happen. Best recommendation is to keep this same FW loaded for now. Avoid updating the RBR. If nothing updates for the 350 series RBS, you could find some new/used RBR750s and load them up to v7 FW then the RBR lastly. Otherwise, run it as is for now.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
SarahJs
May 24, 2024Aspirant
Thank you!! It worked on my phone this morning. Router and both satellites connected once the manual update finished and rebooted the router. On my Orbi app, everything is back to v4.6.3.16 but there is a red msg from Orbi to update. How will I know when they figure out the satellites and allow them to be compatible with the new suggested router update?
May 24, 2024Guru - Experienced User
Enjoy. 📡
