PJDarwin
Jun 29, 2022Aspirant
5G Solution in Australia
I currently have an RBK852 connected to Gigabit Fibre but I am moving to a larger house that does not have fibre available so looking for a 5G solution and have come up with the following solutions. ...
Jun 29, 2022Guru - Experienced User
If it was me? I'm a fan of keeping everything integrated. I'd be going with option 2 if it'd work in AU since its only US based currently.
It even has a wan port if you do ever get fibre/dsl/cable for your home.
How big is the home your moving to? the 8 series can cover quite some area. Not sure how many actual satellites you need.
- PJDarwinJun 29, 2022Aspirant
The house is 750m2 but I am going to put one on the verandah of the adjacent pool hut to cover the pool area. Definitely need at least the 4 units, maybe even a 5th
- FURRYe38Jun 30, 2022Guru - Experienced User
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
