Wizzard370
Dec 06, 2022Tutor
5Ghz channel
Is there a way to change this channel in Orbi353 please?
Dec 06, 2022Guru - Experienced User
Yes. Logging in to the RBRs web page at 192.168.1.1 and select the Basic Tab/Wireless settings.
https://kb.netgear.com/1027/Selecting-wireless-channels
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Wizzard370
Dec 06, 2022Tutor
In Wireless, the 5Ghz option is "greyed out" as 108 (DFS) and I cannot change it.
- FURRYe38Dec 06, 2022Guru - Experienced User
Are you able to change the other 5Ghz channels? 36-48?
- Wizzard370Dec 06, 2022Tutor
There are no others to change. Only 2.4Ghz is listed.
- FURRYe38Dec 07, 2022Guru - Experienced User
Can you post a screen capture of the Wireless settings table?
