san_5678
Aug 06, 2021Aspirant
6 Ghz wifi band
Hi, I recently purchased Orbi (RBR750) Mesh router. When I configured the WiFi settings, I come to know that the 6ghz band is only available for wpa3 mode. Does it mean that I can connect my de...
- Aug 06, 2021
Yes. AX and WPA2 mode is supporting 5Ghz.
Aug 06, 2021Guru - Experienced User
6Ghz is not supported on Orbi AX systems. Will never be as WiFi 6E and 6Ghz is all new hardware specifcations.
If you don't have WPA3 supporting devices, you'll need to keep WPA2 enabled for compatibility.
