marat256
Dec 18, 2022Follower
750 Constantly disconnecting
Hello, I have been having the same issue. The satilite would disconnect on some devices, but still keep other devices connected. It has been happening frequently for me lately. Also, another issue is that the main router RBR750 refuses to let the devices connect to it, so the devices automatically connect to the satellite instead of the router, which is CLOSER to those devices. In order for the device to reconnect to the router, I have to disconnect it and reconnect it. But then, as soon as I go upstairs to the satellite and then come back to the router, the device remains connected to the satellite instead of switching back to the router. My firmware version is V4.6.9.11_2.3.5
1 Reply
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Might try the newer FW version:
Be sure to update the RBS first then RBR lastly.
