Photo-Craig
Apr 29, 2020Tutor
802.11AX Speed - ORBI RBK852
OK folks I need your help. I am very technology savvy, but I am just lost. Topic 802.11AX speed on Orbi RBK852 Wifi 6 Environment: Orbi AX6000 system working just fine Problem: New network 802.11...
Apr 29, 2020Guru - Experienced User
IF your old USB card connected at 1300Mbps then possible something going on with your new AX card. If it supports AX modes, then 2400Mbps should be seen on the 5Ghz radio. 1200Mbps on 2.4Ghz.
Check with the mfr of this new card to see if there is any advanced tuning configurations for it with in the driver UI.
What FW do you have loaded on the RBR?
Im seeing over 1900Mpbs speed rates with my ASUS GT-AX11000 in wireless bridge mode connected to my RBR850:
- Photo-CraigApr 29, 2020Tutor
Im on:
Firmware Version
V3.2.10.11_1.2.12One base and 1 salatite. It is connected wifi 6 to router base.
So frustrating. The MFG support is DOWN during Covid-19. uggggg
- FURRYe38Apr 29, 2020Guru - Experienced User
Ya, seeing alot of support limiations with various Mfrs right now. :smileyfrustrated:
