DaveLeitch
May 29, 2024Guide
850 new satellite syncs but doesn't show up in list of connect devices
Hi I have an RBK 850 system which had the router two ethernet (was 3) connected satellites and a further wireless connected satellite on 2.4 Recently one of the ethernet connected satellites no l...
Jun 02, 2024Guru - Experienced User
The 4th satellite is showing up as a device, not a router. Does the 4th RBS not appear in the connected satellites above?
Does the RBS appear in the top section if you turn OFF all other RBS?
How are you syncing the RBS? Button on the RBS and RBR?
Does using the Add Satellite feature on the RBRs web page successfully sync the RBS to the RBR?
DaveLeitch
Jun 02, 2024Guide
1. The 4th satellite does not appear in the connected satellites
2. I have not done that, as it will mean taking down servers that update data every five minutes, but I will if I have to.
3 & 4. Syncing was done via webpage. That is :
go to web program item "add new satellite" and follow the provided instructions which sequentially are (i) boot up satellite, (ii) press satellite sync button, (iii) click on the webpage next button.
The satellite syncs blue but never shows on the web page.
I have been wondering if I should use the router sync button instead of the webpage and I think that will be my next step.
Further advice always appreciated.
- FURRYe38Jun 03, 2024Guru - Experienced User
Wondering if you generate a new BH password on the RBR, then re-sync using the RBRs Add Satellite feature, if this would get the 4th RBS to appear in the Connected Satellite section.
You'll have to re-sync the other RBS if you try this. Under Advanced Tab/Advanced Settings/Wireless Settings
- DaveLeitchJun 05, 2024Guide
Unfortunately that didn't work either. Might be a rebuild the network thing. Sigh.
- FURRYe38Jun 05, 2024Guru - Experienced User
Wondering if this one RBS is faulty. 🤔
