DaveLeitch
May 29, 2024Guide
850 new satellite syncs but doesn't show up in list of connect devices
Hi I have an RBK 850 system which had the router two ethernet (was 3) connected satellites and a further wireless connected satellite on 2.4 Recently one of the ethernet connected satellites no l...
Jun 03, 2024Guru - Experienced User
Wondering if you generate a new BH password on the RBR, then re-sync using the RBRs Add Satellite feature, if this would get the 4th RBS to appear in the Connected Satellite section.
You'll have to re-sync the other RBS if you try this. Under Advanced Tab/Advanced Settings/Wireless Settings
DaveLeitch
Jun 05, 2024Guide
Unfortunately that didn't work either. Might be a rebuild the network thing. Sigh.
- FURRYe38Jun 05, 2024Guru - Experienced User
Wondering if this one RBS is faulty. 🤔
