MercuryPromoVP
Mar 23, 2025Aspirant
850 satellite won’t connect to 750 router
I have an orbi mesh system with a 750 router and 3-750 satellites in my home with fiber. I bought an 850 kit as I’m having separate service installed in my barn and I needed a router for the bar...
Mar 24, 2025Guru - Experienced User
Make sure the firmware versions are matching between the router and the satellites. That can cause issues.
- MercuryPromoVPMar 24, 2025AspirantI don’t believe software is the same as the router is a 750 and the new satellite is an 850.
How can k update the software on the 850 satellite to match the 750 router?- plemansMar 24, 2025Guru - Experienced User
well if you bought the "kit" it should have a router and a satellite. For each, just download the firmware from the website, then install the "kit" and update the satellites first, then the router. Make sure they're on the same for each kit.
- FURRYe38Mar 24, 2025Guru - Experienced User
You can try this with the incoming RBS850:
