Dd852
Oct 31, 2021Luminary
850 with two satellites - what exactly does "out of sync" mean?
(sorry if you are seeing this twice - it didn't seem to post the first time but I may be wrong) RBR850 + 2x RBS850 V4.6.3.16_2.0.51 1~Gig fibre into RBR I obviously understand the regular Englis...
Dd852
Nov 01, 2021Luminary
Thanks - that’s useful. I will try the connecting via cable trick. (I’m away for a bit of time so will try in my return). They are all allegedly on the same firmware.
There is only about 20’ distance between the satellite and its daisy chain master, but given the construction and design that’s about the best I can do.
Nov 01, 2021Guru - Experienced User
20" is too close unless there is concrete, brick and steel in the building construction...
