Tajee
Aug 12, 2022Aspirant
960 and Fios TV One setup issues
I setup the Orbi 960 and have added all my devices fairly easily until it came to the Fios TV One setup. I have the main Fios One box setup via coax which is fine and is working correctly. When it com...
Tajee
Aug 14, 2022Aspirant
So looks like I will have to keep the 5GHz side of the Fios router on for the Fios One mini streaming box to operate. Was told the mini looks for a hidden channel from the Fios router to connect to. I have turned it on and have set up the FiOS box correctly.
My question is will there be a conflict with having the 5GHz on the FiOS router and the 5 GHz on the Orbi running at the same time? I have named them separately in my Wi-Fi settings.
Aug 14, 2022Guru - Experienced User
Try to keep the 5Ghz channels far apart on the FIOS router and on the RBR.
Try using channel 40 on the RBR and 48 or something higher on the FIOS router.
Also distances between the FIOS router and RBR or RBS should be far apart as well.
