Amirlit
Nov 15, 2022Guide
960 Firmware V6.3.7.5 No more CTS/RTS Setting
In the past, you could find the CTS/RTS settings for wireless under Advanced, Advanced, Wireless settings. But now its not there! Any idea how to find it or change in the new Firmware?
Nov 18, 2022Guru - Experienced User
You don't happen to have another or older wifi router handy would you. Something I've done with some IoT wont or can't connect thru normal or by other means, grab a 2.4Ghz wifi router and set it up using same SSID name and PW as you have on the Orbi system. Use this 2nd router to get the devices connected to it. Once connected, just power OFF the 2nd router, the wifi devices should and will auto migrate and connect to the Orbi SSID name and pw.
Amirlit
Nov 18, 2022Guide
No, I decided to just stop this nonsense. I reverted back to the previous build and...MAGIC! It all started working again. Thats really really REALLY scary. This is < $1000 device. For that amount of money, it should not get WORSE with new firmware. Now I'm scared to death of updating again to even another newer build. I wasted HOURS tshooting this stupid problem. They need to address this ASAP. Its truly UNACCEPTABLE.
Amir
