VFD2
Dec 13, 2022Tutor
960 No more CTS/RTS Setting
Where did the CTS/RTS settings go? The default 64 causes my system to reset daily.
VFD2
Dec 13, 2022Tutor
Not enough through-put at 64 they would tip over when I increased to 512 it stopped happening.
I just want them to put the feature back.
Dec 14, 2022Guru - Experienced User
CTS only effects collisions between the RBR and RBS. 64 is recommended for two or less RBS. 3 or more RBS then CTS values could be increased.
- VFD2Dec 14, 2022Tutor
Right! I have a 1+3 set-up and am missing the field to make the adjustment.
- FURRYe38Dec 14, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)?- VFD2Dec 14, 2022Tutor
6,137sf 😂🤣 Love all your questions; they need to add the functionality back. This system costs too much to be limiting functionality and while they are at it adding the ability to assign devices to the router or satellites would be great.
