jeburnett2022
Jan 01, 2023Guide
A curious bug: NETGEAR-Guest whether I want it or not!
I wanted to try enabling the 6Ghz-only SSID on my RBKE963B (firmware version V6.3.7.10_3.3.3). When I applied the change to enable that SSID, it instead enabled NETGEAR-Guest and NOT the 6Ghz SSID I...
- Jan 02, 2023
jeburnett2022 wrote:
Was any of this documented and something I just didn't read carefully enough?
Documentation? You jest. It's only speculation, but my guess is that when the Orbi is in router mode, the WAN interface is on a separate IP subnet from the LAN interfaces. It is impossible for a satellite to have an IP on the WAN subnet, so there is no point in looking for a satellite out the WAN port. Once the code is written, nobody thought, "Well, if it is in AP mode, then maybe we should look for satellites on the WAN interface, too?"
Once people got their hands on the 960 where both the router and satellites have a 2.5G port, there was a batch of posts about which 2.5G switches people were using to network the router and satellites together. Those discussions were always in terms of the LAN side. The only documentation I am aware of about using wired backhaul is this one:
It shows the switch on the LAN side.
CrimpOn
Jan 02, 2023Guru - Experienced User
jeburnett2022
Jan 05, 2023Guide
Just want to close the loop on the wired-backhaul problem with satellite visibility. Your suggestion to couple the router node to the 2.5Gbe switch in addition to the WAN port, did the trick. Everything is working and visible as it was expected to be.
Sure, the documentation DOES show using the 2.5Gbe port on each of the nodes but it seemed more like a suggested way of doing it, when in reality is a REQUIRED method (for using wired backhaul).
Many thanks!
Jonathan
- FURRYe38Jan 05, 2023Guru - Experienced User
Glad you got it working. Makes more sense to use the 2.5Gb connections between the RBR and RBS for sure.
Enjoy. 📡
