SirSeamus
Dec 05, 2022Aspirant
A friend sold me a CBR750 that he bought on August 13, 2022. I am having issues getting it to work.
A friend sold me a CBR750 that he bought on August 13, 2022. I am having issues getting it to work. I cannot recieve support from Netgear because is is slightly out of warranty. Would it help to re-r...
Dec 05, 2022Guru - Experienced User
You can set it up with out registering the CBR with NG.
However you'll need your ISP to register the MAC address of the CBR so it connects to the ISP services correctly.
https://www.downloads.netgear.com/files/GDC/CBK752/CBK752_QSG_EN.pdf
What FW is loaded on the CBR. You can log into the CBRs web page at 192.168.1.1 if you press the reset button for 15 seconds then release.
SirSeamus
to login to cbr website do I?
Just put 192.168.1.1 in the search or web address bar? and hit enter?
after I push the reset button for about 15 seconds with a paper clip?
