gamenlegend
Aug 09, 2022Guide
About 2/3 weeks ago began having issues where the Orbi
Can I get access to the beta as well. About 2/3 weeks ago began having issues where the Orbi would lose internet connection from my xfinity modem. I tried restarting the modem and doing a manually ...
Aug 09, 2022Guru - Experienced User
There is no beta FW currently available.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is IPv6 enabled on the RBR?
Do you have email logging enabled? https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Enable-Email-Logging-and-Router-Reboots/td-p/2231485/jump-to/first-unread-message
- gamenlegendAug 09, 2022GuideProvider: Xfinity
model#CGM4331COM
Always in bridge mode.
No issue with internet dropping when connecting devices straight to modem via ethernet. Devices connected to orbi router via ethernet lose internet as well.
Yes
The outlined restart process has been done multiple times.
Yes
3600 Sq ft
What is the distance between the router and satellite(s)?
About 70 ft to downstairs unit. Second satellite has an ethernet backhaul.
No. This is something I always disable.
Enabled it after your initial post.- FURRYe38Aug 09, 2022Guru - Experienced User
What mode is your ISP modem working in? Router or Modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry #2 first...
- gamenlegendAug 09, 2022GuideI was editing my reply...
Modem is in modem only mode. Router has been switched to bridge since I recieved it. I always use my own routers so this has always been the setting.
No issue or concern for double NAT
Wireless radios are also always disabled.
Does the front LED turn PINK on the RBR at all?
3600 Sq ftWhat is the distance between the router and satellite(s)?
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless SettingsIs IPv6 enabled on the RBR?
Try enabling it and see if it helps with DNS issues.Do you have email logging enabled?
Lets see if this changes anything...- gamenlegendAug 09, 2022GuideWhy would enabling email reports/logging make a difference? The issue is still occurring.
