gamenlegend
Aug 09, 2022Guide
About 2/3 weeks ago began having issues where the Orbi
Can I get access to the beta as well. About 2/3 weeks ago began having issues where the Orbi would lose internet connection from my xfinity modem. I tried restarting the modem and doing a manually ...
gamenlegend
Aug 09, 2022Guide
Provider: Xfinity
model#CGM4331COM
Always in bridge mode.
No issue with internet dropping when connecting devices straight to modem via ethernet. Devices connected to orbi router via ethernet lose internet as well.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Yes
The outlined restart process has been done multiple times.
Yes
3600 Sq ft
What is the distance between the router and satellite(s)?
About 70 ft to downstairs unit. Second satellite has an ethernet backhaul.
Is IPv6 enabled on the RBR?
No. This is something I always disable.
Do you have email logging enabled?
Enabled it after your initial post.
model#CGM4331COM
Yes
Yes
3600 Sq ft
Aug 09, 2022Guru - Experienced User
What mode is your ISP modem working in? Router or Modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try #2 first...
- gamenlegendAug 09, 2022GuideI was editing my reply...
Modem is in modem only mode. Router has been switched to bridge since I recieved it. I always use my own routers so this has always been the setting.
No issue or concern for double NAT
Wireless radios are also always disabled.
