vajim
Nov 24, 2020Master
AC3000 mesh wifi system (rbk50) vs ax6000 wifi mesh system (rbk852)
Anyone move from the AC3000 mesh wifi system (rbk50) to the ax6000 wifi mesh system (rbk852)..?? Worth it?
Jan 31, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor. Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Im running v12 FW and not having any problems. Manually downlaoded and manually installed. Works for me.
JohnyBeGood wrote:I just upgraded my RBK52 to an RBK852. Everything was the same. Same location for the satellite and the router. Both the 52 and 852 are in AP mode. My router is a Verizon G1100. I upgraded because I have 20 - 30 wifi devices depending on time of day and which devices are running (washer/dryer/Generac). I live in a townhouse community. The wifi is crowded. I have 10 wifi security cameras. Some are dual band; some are single 2.4 Ghz bands. Three cams are inside so only are running from dawn to dusk. I was attracted to the RBK852 since it could handle upwards of 60 to 100 wifi devices. It was based on wifi 6 chip set, with must more throughput and more antennas.
The RBK52 worked well most times. Occasionally, some cameras would drop (no signal) and I attributed that to increased wifi activity in my neighborhood. I decided to purchase the RBK852 to set up for the future with wifi 6 cams and other devices. The install went well. Since I already had the RBK52 in place I just needed to set up the RBK852 the same way, including the SSID/PW. Since the change I have a huge increase in the number of camera drops. I need to do more research as to why this is happening. I am surprised this is happening. The new satellite is the source of most of the drops. (Note: a drop to me is a loss of signal/connection. The connection is reestablished quickly, but the loss is noticeable. All my cams record 24/7 on Blueiris and they FTP to send pics when motion triggers an alarm. The RBK52 handled this. The RBK852 struggles with certain cameras. None of the cams have moved. I did not expect this. I am running the latest firmware (V3.2.16.22_1.4.9). More research from me.
JohnyBeGood
Jan 31, 2021Aspirant
Thanks for the help! I will check into it. Friday night I switched back to the RBK52. Since both systems are setup exactly the same it is easy to do. I am gathering stats from both systems. Note: I am using NetSurveyor to monitor the wifi signals. The RBK852 backhaul signal is rated as excellent and the Orbi app says it is good. I believe the issue is more the devices connecting to the satellite and to the router. Both systems are setup in "AP Mode" and the Verizon router has both wifi bands disabled. My RBK52 has been running successfully now for nearly three years. I will check out the faq you mentioned.
BTW, should I open a new discussion for this? I chose this one because I wanted to relate what I am experiencing upgrading from RBK52 to RBK852.
Again, many thanks!
- FURRYe38Feb 01, 2021Guru - Experienced User
Ok, let us know. I would open a new post if your system doesn't seem to work and then we can troubleshoot it there.
JohnyBeGood wrote:Thanks for the help! I will check into it. Friday night I switched back to the RBK52. Since both systems are setup exactly the same it is easy to do. I am gathering stats from both systems. Note: I am using NetSurveyor to monitor the wifi signals. The RBK852 backhaul signal is rated as excellent and the Orbi app says it is good. I believe the issue is more the devices connecting to the satellite and to the router. Both systems are setup in "AP Mode" and the Verizon router has both wifi bands disabled. My RBK52 has been running successfully now for nearly three years. I will check out the faq you mentioned.
Again, many thanks!
